Sponsored by:
Sponsored by:
94 Camry sludge after rebuild
Old 12-01-2008, 11:17 PM
rlcookejr's Avatar
Default 94 Camry sludge after rebuild
I have a 94 Camry with 150,000 miles. The engine was getting hot, but not overheating. Running very badly. Was going to replace the head gasket and found grooves in one cylinder. So I decidedto rebuild the engine. It ran great at first. After a couple of oil changes it started to develop sludge. At one point it was so thick that there was no oil on the dipstick. The oil seemed to be staying in the upper half of the engine. Ran engine cleaner through it and drained and repeated several times until the oil looked right. Was good for awhile and now it is sludging again. Idles ok. When put in gear it runs horribly. Any thoughts or suggestions?
Old 12-02-2008, 05:34 AM
pedro's Avatar
Default RE: 94 Camry sludge after rebuild
What's the weather like where you're located? What are your driving habits, short run before engine heats up? Does engine heat to proper temp? What grade oil are you using?
OldElPaseo
05-18-2012 05:17 AM
Rex Kramer
01-17-2012 05:30 PM
dinenasty
01-31-2011 12:24 AM
dagger440
06-15-2010 07:06 PM
prwilliams2287
12-17-2007 08:35 AM
Quick Reply: 94 Camry sludge after rebuild
