Sponsored by:
Sponsored by:
95 camry makes poping sound and wont pull
Old 01-16-2010, 09:26 AM
the.stick's Avatar
Default 95 camry makes poping sound and wont pull
my camry makes a clicking/poping noise and does not want to pull when you turn but does fine going straight cant find problem any ideas would help thanks
Old 01-16-2010, 09:45 AM
If these noises occur when you are turning check the outer CV joints for failure. The bad joint is typically on the opposite side of the direction of turn the noise occurs on.
If the noise occurs when turning left, check the right side outer CV joint, etc.
If the noise occurs when turning either direction check both joints and also suggest you check the differential to make sure it has fluid.
Old 01-16-2010, 10:48 AM
the.stick's Avatar
the cv joints are ok can diff work fine going in a straight line but not pull going around a curve
Amekaji87
12-04-2011 02:39 PM
meagan_maleigh
03-18-2011 11:12 PM
beige97camry
08-26-2007 03:36 PM
beige97camry
08-21-2007 09:59 PM
jnthn
04-23-2007 04:28 AM
Quick Reply: 95 camry makes poping sound and wont pull
