95 LE backup light problem
I have a 1995 Camry LE and the backup lights fail to light when the ignition switch is on and the car is in reverse. It is an automatic transmission. I also noticed that when the transmission is in drive, the D on the dash does not light, but all other light work in each position of the gear selector. I am not sure if the two problems are related or not. The first thing that comes to mind is a switch failure. Is the backup light switch on the transmission or part of the gear selector? Does anyone have any ideas on what to check first, besides the bulbs?
RE: 95 LE backup light problem
Always check simple stuff first:
1. Bulbs
2. Fuses
3. Electrical contact (make sure all the connections are clean and will provide a good electrical contact.)
If none of these are your problem the problem is in the wiring itself. Which translates to get a multimeter and get to tracing the the lines and check voltages where ever applicable.
Best of luck,
Black00GTS
1. Bulbs
2. Fuses
Best of luck,
Black00GTS
