96 camry has a slow draw on battery possible airbags?
96 camry was wreckd while back and bags deployed.i got hte car fixed now there is a slow draw on the battery.we check all the fuses under the hood and that came back good.only thing we can figure out is the airbag light is stayin on so is there a fuse hidden somewhere for the airbags.the driver side has already been replaced.Any suggestions
If airbag light is staying on there is a problem with the airbag system. The airbag computer does checks the system each time the ign switch is turned on. If a problem it does not go out.
In addition to replacing the airbag the bag activator needs to be replaced. This is a switch that is triggered when the car hits something from the front. The switch then activates the airbag. The switch may be in the center console area between the front seats under the console trim.
