Sponsored by:
Sponsored by:
98 Camry 2.2/P0171 System too Lean(Bank 1)
Old 03-13-2012, 10:51 AM
Debunker's Avatar
Default 98 Camry 2.2/P0171 System too Lean(Bank 1)
Hi all,
this code has come up (randomly) 3 times now within a month.
1 time it had 2, PO171 codes. Each time I went to Advance, and
checked/cleared the code with their scanner.
No change of operation noted, except 1 time when it threw the
code; I noticed the idle going up and down EVER so *slightly*
(not much variation at all, but enough to see the tach going up
and down a tiny amount).
No drive-ability issues at all seemingly for each time it threw
the code(s) though!! Car has 170k on it.
The car runs fine otherwise, runs smooth, idles fine/smooth.
I seem to be coming up with people saying the MAF sensor
could be dirty/need a clean OR an O2 sensor.
BUT, the 6 cyl has a MAF sensor- I'm reading the 2.2l does not
have a MAF- and to check on the MAP sensor??!
I've also read the rest of the recommends- fuel filter, pcv valve,
egr (clean/replace) valve, etc...
I've also read, that a couple people just put in fresh plugs; and
their P0171 code issue went away!!!!!!
I was going to order a new O2 sensor (actually air/fuel ratio
monitor) anyway, just because I recently bought the car; and
wanted to get it replaced (hopefully picking up any MPG I can)
because I can't say the last time it was replaced.
Thanks in advance people!!!!!!!!!!!!
Sincerely, Bob Z.
Old 03-13-2012, 08:08 PM
What is the current MPG?
Issues that can cause the code:
Intake air and exhaust leaks
Fuel pressure/injector plugged
O2-A/F sensor
MAP sensor
Coolant sensor for computer
Change the 02 sensors and determine what happens.
Old 03-14-2012, 01:06 PM
Debunker's Avatar
Hey again Joey...
thanks again for responding!!!
I cant say exactly what the mileage is
for sure (haven't really been tracking
this tankful).
However, I'm going on 110 miles; per the
quarter tank its used since filling. And I
think my tank is a 18.5 gallon capacity?!!
Sincerely, Bob Z.
Old 03-29-2012, 09:44 AM
Debunker's Avatar
Hello again folks,
just an update for me... I just replaced my A/F ratio sensor
(finally) on my 1998 Camry 2.2l. (as Toyomoho had suggested).
Cleared the code that kept popping up randomly-
P0171 System too Lean(Bank 1)(Sensor 1)
All seems to be fine now- no more light...... THANX
Toyomoho!!!!!!
Will report on mileage soon............!!
Sincerely, Bob Z.
Old 03-29-2012, 09:58 AM
Great.
Old 12-29-2013, 11:33 AM
jljbtm's Avatar
I have that code on my 99 v-6 does it have a A/F ratio sensor? and where is it?
Old 01-01-2014, 12:32 AM
o2 sensor(s)
Old 01-01-2014, 09:30 AM
Debunker's Avatar
Hi,
its located way up on the exhaust manifold,
near where the manifold meets the engine
(almost). The A/F sensor is a bit more
sophisticated than a regular o2 sensor I'm
to understand.
Price out yourself a "direct fit" A/F sensor,
put a little anti-seize on the sensors threads
before installing; clear your codes out after-
and you should be good to go!!
Sincerely, Bob Z.
Old 01-02-2014, 06:25 PM
jljbtm's Avatar
Default Average lifespan?
Whats the average lifespan of a Toyota Camry ????
My son in law just lost the 4 cyl. engine in his 99 camry 195xxx
and my daughter has a v6 1999 Camry with approx. 130xxx
Old 01-03-2014, 01:47 AM
Generally, take care of it and I have heard of Camry's going to 300K. Just maintain it and know the trouble spots for your make and model. What exactly happened to the '99? Did it seize, throw a rod, over heat, etc.?
Quick Reply: 98 Camry 2.2/P0171 System too Lean(Bank 1)
