99 Camry 3.3 ac issue
My camry ac is not blowing cold, t-stat was changed and cooling system flushed. AC worked fine today it just blew out cool not cold like it had been. I checked the freon and it is full(checked with Manifold gauge. Any ideas? Someone mentioned that the resistor might been the issue but I thought that was just for blower fan speed.
Sorry 3.0
Did you check high/low pressures?
Resistor is for blower speed but should have high speed even if bad. Any chance the evap coil is plugged with debris, air door problems, etc. |
I checked low side only, blower works fine which leads me to believe that the resistor is fine. Did not check for debris yet though.
