'99 XLE Keyless entry module location??
I'm trying to locate the keyless entry (alarm) module on my '99 XLE. Its not under the drivers seat as in my '97 LE. By the dash indicator, it looks like the factory installed Fujitsu RS3000, but I'm not sure. Any help is appreciated. Thanks
Len |
RE: '99 XLE Keyless entry module location??
i know to program new remotes or reporgram old remotes we have to jump terminals that are found behind the dimmer/mirror switches. you just pry the edge and it pops out. but im not sure if thats what you're looking for.
Nor am I. The XLE came with no remotes. I was reading up on the Fujitsu system, and I understand the lower button is for an additional auto. I will look at jumping the connector, but I am confused now if this is the same system. I would buy some remotes if I could be sure what type I need.
Len |
Finally found the remote box by following the wires. Mine on my daughters 98 camry located behind the remote mirror switch. Black box held up by a tie strap. Push the green reset button to set your key chain.
