AC 2002 camry
The AC light flashes on my 2002 camry LEand during the flashes doesnt work. Once the AC is turned off and then back on it will work after about 10 seconds. Anyone know what the problem may be let me know
thank you |
RE: AC 2002 camry
There's a TSB involving an update AC compressor relay. Basically, the flashing light is on because the ac compressor revolution sensor detects the compressor is slipping. It's slipping due to the relay failing to pass enough voltage through it to completely lock down the compressor clutch. An updated relay was created to fix this.
Joel, CA |
