air conditioner drain
We recently hit a shreaded tire going down the freeway. Since then water from the air conditioner condenser is getting inside the passenger compartment instead of draining outside on my 2005 Camry. I can't find the return/drain line. Anyone know what I should look for?
Rubber tube coming through firewall on passenger side. The tube is attached to the A/C evaporator box. You may need to pull the evaporator box to replace.
