ATF filter change
Old 08-14-2015, 09:53 AM
indiglofish61's Avatar
Default ATF filter change
I had my ATF filter changed in my 2006 Toyota camry LE 4 cyl about 6 months ago I am wondering how often should I change it, I am going to change the ATF that's Is why I am asking, because its a lot of work just to change the filter, cause I have to lift up the supports or what ever you call them to get to some of the bolts. Another ?, are all the camrys like that, I mean to get to the bolts on the AFT pan?
Old 08-15-2015, 12:00 AM
Most owners never change the filter.
Concentrate on changing the fluid.
Old 08-15-2015, 12:03 AM
I wouldn't even bother with the filter until 100K.
Old 08-17-2015, 12:10 AM
just wondering, If i change the ATF like every 3 to 6 months would I still need to change the filter, even after 100k?
Old 08-17-2015, 05:02 PM
The owners manual only states to change the fluid, never mentioned the screen.
Old 08-20-2015, 08:48 AM
TruchoCamry's Avatar
You can change it(pn-35330-08010,in case you do), but as they have stated above...you don't really HAVE to change it...
MoonRiver
09-15-2012 01:06 AM
sjrugged
03-25-2009 04:25 PM
Axxis8203
02-05-2009 06:42 PM
zcpro
01-12-2009 01:59 PM
jairopion
09-22-2008 09:40 AM
Quick Reply: ATF filter change
