Battery doesn't hold a charge even though battery and alternator are new
Hey all, I'm new to this website. I have a 1987 Camry (4 cylinder, 4door). I don't really know much about cars, plus my usual mechanic is stumped, so I thought I'd bring my situation here. My car has 187,000 miles on it. I bought it used at 156,000 miles. Beginning 1 year ago, the car battery started holding less and less of a charge, giving a slow crank at startup. Eventually, the battery would no longer hold a charge from the alternator, and died alltogether. I went and bought a brand new batttery for the car. Within 2 months, the (new) battery was dead, also no longer holding a charge. Took my car to my regular mechanic. First thing he did was start the car, then disconnected 1 of the battery terminals. The engine immediately died. He explained to me that the problem was the alternator. It was no longer working properly, so it no longer giving the battery (or the engine) the juice they needed to stay operational. He said the car needed a new alternator. He put on a brand new alternator, and charged the battery to full capacity. New problem. Even with a brand new alternator and a fully charged battery, if I let the car sit for more than approx. 7 days without using it, the battery completely dies alltogether giving me NO crank at startup, not even an ignition click when I turn the key. Took the car back to the mechanic. He tested the output voltage of the alternator and said it was perfectly in spec for my car. I suggested putting in a stronger powered alternator. He said an alternator with too high a voltage output will overcharge and damage the battery. I have not been back to him since. What I did (for the meantime) is bought a Schumacher portable charger. When the battery's cranks start sounding too slow, I take it out, charge it overnight, and put in back in the car before going to work the next day. I have to do this 2 or 3 times a month.
My question to you all is, what could be making every battery that I put in that car drain within a week of non usage? If the alternator is in spec and works, why is the battery not getting charged sufficiently during normal use? And why would a fully charged car battery DRAIN EMPTY if the car has not been driven for 5 to 7 days? Any help regarding this matter would be GREATLY appreciated! |
Originally Posted by the desolate one
(Post 65820)
If your handy with tools. When not driving the car for a time, disconnect the negative battery terminal to stop any drain. When going for a drive, reconnect the battery. If the battery is still charged there is a drain.
Don't disconnect the battery cables with engine running as this can damage the alternator. |
