Brake Life?
How long do the brakes usually last on a camry. 2.5 sedan ?
That is going to depend a lot on how you drive and how much. It can also depend on what kind of brake pads you use as some wear quicker than others.
I'm just after ballpark, how long did yours last?
Barring issues or a lot of braking 50K.
Be sure to also monitor rear pads. |
Agree with toyomoho.
Thanks.
do the rear pads usually wear out first?
Not typically. The fronts tend to do most of the work therefore wear out sooner. All that being said, I typically do all four corners when I do brakes but is not usually necessary.
That's what I always thought, but when I was shopping for a camry I remember there were 2 cars that had there rear brakes replaced. Just curios bout that one.
