A/C Light
A/C Light
I've got an 02 Camry and the other day I had my a/c on. Suddenly the light on the **** started blinking and I lost cool air. I turned it off and left it off for a minute or so and turned it back on. It ran fine again for a few minutes and then the same thing; blinking light and no cool air. I again turned it off for a few minutes and then back on. This time I have not had any of the same problems? Anyone have any ideas about the cause before I drop a lot of money on the a/c? I live in the south and it's getting to be about time that I will need it the most!!
RE: A/C Light
Hi ...
mmm ... lets start now ...
1st do what as toyboy suggested ...
2nd check all ur fuese's regarding the cooling system ... gas level ... & compressor swithch .. comp switch has a timer to turn it on & off .. it might be dirty as u have to clean the trerminals & re-hook it again & check other wise u can check it to direct connect the compressor without the swithc as if its working ok then u have to change the switch.
do it with the assistant of an a/c tech if u dont know how to do it for that i guess he wont charge u lot as if there is a problem the cost will be droped if u gonna repair it in his shop.
good luck
good luck
hardyrxp
04-06-2010 09:09 AM
