A/C only half the car???
Hey guys, I did a search but didn't find any similar issues -
My wife called and said the air conditioning is only coming out on the passenger side. The drivers side is blowing outside temp air. Also, the A/C button light does not turn off when you push it. And, the Max A/C, or recirculate light, won't go out either. Any ideas? 2007 Camry SE, 4-cylinder, 85k, regular A/C, no dual zone, or climate control |
I'd say that your climate control unit is b-a-d. unless you have fan settings or temp settings not allowing a/c to kick in. which I doubt, if you checked on all that.
honestly, did YOU look at it? based on wife's call..... I'd check everything first myself. |
