Camry 200SI starting
Hello
Can somebody please help me. I have a Camry 200 SI 2000 Model. The car does not want to start. The Engine turns over normal once the Immobiliser is activated (I also used the By-Pass in the Boot to Bypass the Immobiliser/Alarm) Engine just turns but no start. Any ideas/advice please, Thank you in advance. |
If all electronics are working properly, make sure the engine is getting fuel.
Do you smell gas after cranking the engine over a few times? |
Thanks for the advice Patonium. The end result was interference from the Anti-Hijack unit causing a Voltage drop to the Fuel Pump.(Low Voltage). Replaced anti hijack unit. Thanks again for advice, much appreciated.
Glad it is fixed! Thanks for posting back.
