Sponsored by:
Sponsored by:
Changing manual trans fluid
Old 10-11-2015, 03:07 PM
gnx547's Avatar
Default Changing manual trans fluid
I want to change the manual trans fluid on my 97 Camry v6. Is this the fill port on top of the trans? What brand gear lube is good to use? About how many quarts does the trans take?
Old 10-12-2015, 11:16 PM
That does look like the fill port. Make sure you can get that bolt out first before draining.
What model transmission is it?
I need to change my manual transmission fluid as well and through some research, I hear great things about Amsoil.
Old 10-13-2015, 06:48 AM
dirty hands's Avatar
updated my camry manual gearbox list .... there are gaps in my research
might it be a 1mz-fe engine fitted ? then it should be E153 (1997-2001 Camry 1MZ-FE),
if so page one second picture of pdf shows positions
http://www.lotussport.org/manuals/Co...ts_Removal.pdf
the filler plug is on the front of the box ...
and the drain plug should be somewhere near the part of the casing
Old 10-13-2015, 12:37 PM
gnx547's Avatar
I don't know what model transmission it is. I thought all the 3.0 V6 manual transmissons are the same? How many quarts of gear lube do I need to fill it up?
Old 10-14-2015, 02:21 AM
sorry cant answer that in quarts
im in australia .. i start .with 2 litres
then I use the old school -- little finger in the filler hole method
if oil is seen on the finger there is enough oil in the transmission
Old 10-19-2015, 02:15 AM
Good pointers, Dirty Hands!
gnx547
06-27-2015 06:48 PM
Suny
12-09-2013 02:06 PM
EagerBeaver
04-01-2009 12:54 PM
anaab
07-03-2008 06:13 PM
melahi
06-20-2008 09:49 AM
Quick Reply: Changing manual trans fluid
