check engine,VSC light and trac off stay on
Howdy, anyone out there know why this might be happening? They all just went on today and won't go off. HELP! Thanks
RE: check engine,VSC light and trac off stay on
omg. just happened to me. what hell ive been going through this week. its been 5 days to change spark plugs on my 02 SE. and when i got my car back same lights came on. mechanic says not his fault. i don't know what to do either because my car now jerks and is making a loud noise from glove box area. let me know if u get any info please!!!!!!!!!!!!!!!!!!!
I am having same problem on my 2004 camry. Anyone have answer? I checked the gas cap. The week before I took the car in for inspection and they also rotated the tires, checked the engine air cleaner (did not replace it), and changed the oil. I have been driving the car but the"check engine,VSC light and trac off stay on".
you guys will need to retreave the troble code stored in the ecu. if you want help..
My check engine, brake light, reverse light, tail light out light, etc were all on for no reason. I checked the wire spool in my trunk and there was a wire that was cut in half. I reconnected it and now only my Brake light is on. Maybe not the same issue, but this helped me to look in the trunk.
