Cooling fans won't run
Old 07-23-2011, 09:39 AM
rixemailfl's Avatar
Exclamation Cooling fans won't run
2000 Camry with the 4 cylinder.
OK... I checked the other threads about cooling fan issues...
Disconnected the wire/plug at the bottom of the radiator. No fan operation at all.
Fans do not operate while the A/C is on either...
Engine overheats when stopped, cools to regular temp when moving. A/C works GREAT while moving, gets warm while stopped.
So... What should my next step be?
Old 08-05-2011, 03:47 PM
rixemailfl's Avatar
Thanks for all the replies...
Old 08-05-2011, 10:42 PM
The fans are 12V, test the fans for operation by applying 12V.
If Ok may be a relay. Check the 30A RDI circuit breaker and the No 1 fan relay.
Old 08-07-2011, 02:39 PM
rixemailfl's Avatar
Thanks! for the response toyomoho!!
The fans do operate when wired directly to 12V.
Will check the relays & RDI circuit breaker...
getcrunk88
03-05-2014 08:06 PM
darimura
05-18-2011 09:09 PM
brianjrealtor
03-11-2010 10:05 AM
ashpond
01-11-2009 06:42 AM
paul1264
03-15-2008 06:02 AM
Quick Reply: Cooling fans won't run
