the dreaded 1988 heater core replacement
Hi...first timer here. I've just begun to replace my core and was wondering if I'm reading the haynes book right. Do I need to remove the entire dashboard/instrument panel and center console to gain access to the cooling/heater box? I have the whole bottom dash out and have removed most of the mounting nuts for cooler box but it's not budging. I also replaced the hoses and t-stat, plus a coolant flush. This job is a bear! Thanks!
It appears so but suggest you ask at the Toyotanation website for confirmation.
Is it leaking, plugged, etc? |
it's leaking all over the carpet right from where the cooler box and heat box connect.....and the defogger is not working properly. I have every nut and bolt I can find off the dash panel but it's hanging up on something. Once I get this off, it should be pretty easy from there. I'm gonna replace all the light bulbs and the foam around the vents while I'm in here. Thanks
