driver seat seperating
2012 -- the area u sit on is seperating from the right side outer trim area that is a different color. No thread appearing, is this glued together?
1 Attachment(s)
on typical mass produced seats
the fabric trim sections and outer is sewn seams and joins then pulled over the glued ..shaped foam of the seat a fix that lasts remove the seat from the car the seat cover needs to be released from the seat frame (special clips/staples ) and re sewn at the joins.. new foam shaped if damaged . then repaired fabric cover re fitted to the seat frame options a motor trimmer to repair find a wrecking yard with same 2012 camry model trim and seat and replace the whole seat |
since no threads appearing, not sure if sewn, though u could be right since I did add some foam to the seat 2.5 yrs ago since I was hitting bottom-toyota & honda have hard seats. It might of happened during that repair & they didn't sew it or just blew it off & I just now noticed it. It's a power seat in nice condition, it's minor now unless it gets worse. Just wondering if i could bead a line of glue in the split?
