Driver side front door
This is my first post. I have a '95 Camry. It's very basic. 2.2L 4 cylinder, 5 sp manual tranny, manual windows & locks. Anyways, the front driver's door won't open. I assume the arm that connects to the latch is broken or came off. It won't open from outside or inside. How do I remove the door panel, if I cannot even open the door?? Or how do I open the door to remove the panel & fix it?? Any suggestions??
RE: Driver side front door
get your self a slip jim and try to find the broken rod inside the door. if you get a hold of it and give it a tug it should unlock and then you can fix it
