EGR removal and cleaning 5S-FE
I got a 92 Toyota Camry LE 2.2L 5S-FE engine. The check engine light is on and the code is 71, EGR valve. I have trouble taking the EGR valve out to clean it. The trouble is trying to get the bolt that connects to the pipe loose. Any tips? Thanks.
RE: EGR removal and cleaning 5S-FE
try runnine some sea foam through your pcv valve it usually hits the egr. but, being a 1992 its quite poissiable that your egr needs to be replaced.
I have run Seafoam through the brake booter vacumm line. I'll try running to the PCV valve worth a try. Thanks.
