engine noise when hot
my car is a 99 camry 2.2. with 178,000 miles. recently did a timing belt, water pump. been noticing when motor gets warmed up, there is an audible whirring noise coming from the engine compartment. not loud, but you can hear it. no noise upon start up. replaced the alternator because it was cheap. no change. what do I do next. looking to run this car into the ground, so I want to find the source of the noise. runs fine. tranny drained refilled at 150,000. any help appreciated. thanks, john
Use a section of rubber hose as a stethoscope to narrow down the area of the noise. Then report back.
unable to pinpoint noise. had the tranny drained and refilled. fluid was dark brown. still has noise. like I said, no noise when cold, only after warm-up.
Did the noise start after the timing belt change?
I think it did. new parts were from 1aauto parts. thought they were good parts?
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received |
this is what happened when i tried to send video of the noise.
Go to the vbulletin.com website for help on your problem with video.
trying to send video again. not interested in that website you directed me to. my goal is saving money. thanks , though for your help on my camry problems.
"Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received" The above message appears to be a problem with your computer settings. The website directed to powers this forum. It has information on why you are getting this message. |
