Europe/US
Hi,
Food for thoughts. I find these differences funny. Recommended engine oil change: US : every 3000 miles. Europe: every 6000 miles since 80's, every 12000 since end of 90s, now every 24000 or even more. Diesel and petrol. Rotating tires: US : still yes Europe : don't do since 80's (the average travel speed is much higher in Europe) Timing belt change Europe : all roller/tensioner bearings must be changed with the belt, no guarantee otherwise US: changed only if they "look" worn Change periods are roughly the same Brake pads: Europe : pads are never surfaced ; pads must be changed when rotors are changed US : no rules, pads are surfaced |
RE: Europe/US
I don't understand what you mean - "end of 80th, 90th". 80th what?
RE: Europe/US
ORIGINAL: buffitz I don't understand what you mean - "end of 80th, 90th". 80th what? end of 80th means end of the 1980-1990 period. I'll fix that. |
RE: Europe/US
Recommended engine oil change: US : every 3000 miles. Europe: every 6000 miles since 80's, every 12000 since end of 90s, now every 24000 or even more. Diesel and petrol. 1) the motor oils sold/used in Europe (i.e. more stringent ACEA standards) are of higher quality than the motor oils sold/used in U.S.(i.e.less stringent API standards). 2) difference in fuel contents/formulations: supposedly European fuel formulations are somehow less harsh on oil than U.S. fuel formulations 3) difference in average driving cycle: supposedly European driving cycles (e.g. longer durations; higher peak operating temperatures) are less harsh on oil than U.S. driving cycles (e.g.shorter durations;lower peak operating temperatures) Tire swap: US : still yes Europe : don't do since 80's (the average travel speed is much higher in Europe) Timing belt change Europe : all roller/tensioner bearings must be changed with the belt, no guarantee otherwise US: changed only if they "look" worn Change periods are roughly the same Brake pads: Europe : pads are never surfaced ; pads must be changed when rotors are changed US : no rules, pads are surfaced |
RE: Europe/US
About oil.
The oil we find here in the store is the same as in Europe. At least Mobil/Motul/Shell/Castrol and similar. And it's much cheaper in the US. These oils are all both API and ACEA rated. Not sure about the one from Juffy Lube. The petrol is of higher octane rate in Europe, which means more additives. So I presume it should hurt more the oil. The manual transmission makes drivers rev the engines higher than US auto trans. You never stay under 2000RPM (petrol cars). It's difficult to estimate the impact of driving cycles. The auto transmission (rare in Europe) makes people stop in Drive position, which means the engine is more loaded then when really idling. This is certainly bad for the oil. I'm not sure the town driving conditions are worse here. I think all that does not explain such a HUGE difference. With the same oils and same engines (sure v8 are rare in Europe). The only "modern" car I know with shorter recommended oil change is Maserati biturbo (82-98 era). Maserati recommends every 7,500 km, 4700 miles. Full synth 10w40. Note that I'm talking about 250-305hp 2L or 2.8L v6 turbo engines driven like performance cars. Actually people changes every 10,000km and there are no known problems. But even in Europe there are interesting phenomena. For example recent diesel engines, which run twice higher compression ratio and almost as high RPM as petrol ones, don't need break in. While petrol, which in theory need less precise machining, still need it. ORIGINAL: diver1972 Tire swap: US : still yes Europe : don't do since 80's (the average travel speed is much higher in Europe) |
RE: Europe/US
About oil. The oil we find here in the store is the same as in Europe. At least Mobil/Motul/Shell/Castrol and similar. And it's much cheaper in the US. These oils are all both API and ACEA rated. Not sure about the one from Juffy Lube. Check out thesearticles for some good reading on the topic of ACEA vs. API oils: http://www.smartmotorist.com/car-acc...fications.html http://americascarshow.com/Detail.as...8&mid=1682 http://mysite.verizon.net/b5crazy/si...ec_article.pdf The petrol is of higher octane rate in Europe, which means more additives. So I presume it should hurt more the oil. The manual transmission makes drivers rev the engines higher than US auto trans. You never stay under 2000RPM (petrol cars). It's difficult to estimate the impact of driving cycles. The auto transmission (rare in Europe) makes people stop in Drive position, which means the engine is more loaded then when really idling. This is certainly bad for the oil. With the same oils and same engines (sure v8 are rare in Europe). Yes, sorry. Rotating. It does not exist. On my "normal" cars the tires last 30-40,000 miles. |
RE: Europe/US
I'm used to read standards on the oil packages because I own(ed) few performance or tunned cars. I'm absolutely sure brand oils like Castrol GTX or Motul 300v are the same here and there. They all state all these API/ACEA/Audi/Mercedes standards which don't really help us to know if the oil is good. You can find almost any mix of standards providing they are "synthetic technology", which BTW does not mean a lot of things. The only "reliable" indicator is the price. Good pure synth oils are very expensive. But we don't need them is regular cars. I admit that in France you can buy any "synth tech" oil in supermarket and be sure it will work well in any regular car.
However I think like you that the average US oil is of lower quality. Why would they be better if customers are educated to change them every 3000 miles ? It's like trying to explain in the US that a 2L turbo car can be as performant as a 5L NA US v8 one. So the conclusion would be here: don't go to Jiffy, use good brand oil (it's easy to check how the same oil is rated in the UK for example) and you can change it as in Europe. With one remark: we are expected to change oil every X miles AND every year. So when Audi says you can change it every 25000 miles it's likely good for taxis but not for average customers. So no need to pay a very expensive pure synth oil. This is how I understand the idling. Idling is bad because the engine efficiency is very low at low RPM. Most of passenger car engines are designed to be optimal around 2500-3000 RPM and start to have a decent/good efficiency at 1500 RPM. Low RPM makes poor combustion (low turbulence and combustion speed, so more unburned HC), poor ring sealing (poor ring lubrification and higher HC level which enters the oil) and poor cylinder scavenging (low gas speed). Higher load at low RPM created by idling in gear makes a greater oil contamination as all these phenomena are amplified, even if HC level may stay the same. Anyway idling is bad for the engine, it should not exist. The impact of fuel additives is that they are very volatile and can be more easily transported anywhere in the engine. And of course as the fuel is better, the combustion pressure is higher, so oil works in harder conditions around rings. Pistons are cooled by oil, not water. |
