Front end squeaks over bumps.. HELP
I have a 2000 Camry LE with about 74000 miles on it. Everytime I hit a bump, the front end squeaks. I am not sure what it is. I know nothing about cars. The only time I hear it is when I go over a bump, and the front end comes down. When I go over a little bump and the front end just moves, it doesn't happen, but when I go over a decent bump in the road and the front end actually comes downa little from, then it squeaks. Everything rides fine with the car from what I can tell, its just annoying to hear it. What could this be? How much do you tihnk it would cost to fix?
Help is appreciated. Kenneth |
RE: Front end squeaks over bumps.. HELP
Sounds like the upper strut mounts- a common squeek point in the front suspension. Requires strut removal, disassembly- and replacement of the upper strut. Good Luck!
J |
I can get the parts for 80 dollars a side.
