Front Passenger Door will not open
The front passenger door of my '98 Camry will not open from inside or the outside. When I try the door handle from the outside it seems as though it just does not engage. The same is true with the door handle from inside the vehicle.
Also, my back drivers side door does not full close. Any info on either of these issues would be much appreciated. Thanks Mike |
Your best bet for the front door may be a locksmith that works on cars. They may have a special too, etc. Otherwise the door panel needs to be removed or a hole cut in it.
On the rear door check the striker plate on the chassis, this can be adjusted by loosening the screws. |
Hi,.
i need 2 keys cut for my e36, anyone know a guy i can go to? every locksmith around my house says they cant cut this type of key. looking for anyone in queens or even brooklyn. thanks -------------- locksmith nyc |
