Fuel leak under car
1 Attachment(s)
My daughter has a 1995 Camry Wagon, V6. There is a fuel leak coming from a small rubber hose under the passenger side of the car, just behind the front tire, and behind the engine. This hose looks like an overflow of some kind because it isn't connected to anything. Any ideas what's causing fuel to leak from there?
You sure the fluid is gasoline?
This looks like the water drain pipe for the AC evaporator. |
Originally Posted by jazzb0ne
(Post 96645)
did you find where the gas was coming from ? I have a friend with a 2009 Camry that has gas leaking from the same point as you did. |
Any update?
