Glove box
Old 02-03-2015, 01:25 AM
Camry owner.'s Avatar
Default Glove box
Hi all, I am new to this forum.
After doing a search I still perplexed.
05 Camry. Glove box keeps opening while driving. I have taken it out and had a good look. It seems like the retractable tabs have little resistance.
Is this a common problem? Is there a fix for it?
Old 02-03-2015, 11:24 PM
I'm not aware of any particular fix for your issue but I can recommend somethings.
First, most glove boxes have some adjustment that can be made with the latch. It is
Usually it is the latch attached to the dash and not the glove box door. Sometimes you can move that latch a little bit forward or aft for a nice flush fit.
Another option would be to take apart the latch on the glove box door (assuming that the tabs are spring loaded) and stretch the springs a little so they regain some tension under load.
Just some thoughts. There are also junkyards and eBay...
Old 02-04-2015, 05:28 AM
Thanks for the reply.
Turns out there are 2 clips that go into square holes that the retractable pins latch on to. Both were missing.
Old 02-05-2015, 12:06 AM
Did you get new ones?
Old 02-05-2015, 05:13 AM
Will try tomorrow.
mark garrett
08-10-2014 10:49 AM
mark garrett
07-26-2014 01:30 PM
ToyCam
09-27-2010 11:36 PM
fritzer
06-20-2008 02:19 PM
tijas2
09-30-2007 03:14 PM
Quick Reply: Glove box
