Has anyone here installed a repair crank sleeve?
I have a 95 Camry with the 2.2 and the oil seal keeps on leaking. I already replaced it with an OEM and National brand and still it leaks. I'm thinking there is a worn spot on the crank causing the seal to leak. There a repair crank sleeve available, but where does it get installed into? The snout of the harmonic balancer? Or inside were the crank seal goes into? Has anyone here installed a repair crank sleeve?
its a thin metal sleeve
to give the timing cover oil seal a new surface to run on
force it ,,hit too hard or start of crooked and the sleeve will be useless
a plastic hammer works ok for me
ebay kit suppliers picture
second picture
i prefer the kit that comes with the ring and application tool
i cant find a listing for the 95 2.2 camry
timing cover off
you emery paper the crank so its a smooth as you can get it
fit the ring by
gently and slowly taping it on in a circle onto the crank till thin edge is flush with crank end
job done
second picture
timing cover off
fit the ring by
job done
it will... if you can find a supplier for the second kit to suit a 2.2
in my search
i didnt find a parts listing that said the second kit was compatible for the 2.2 the mitsubishi
it is my preferred kit for other makers engines
you would have to ask the suppliers for that type of kit
to see if they had that type of kit for the 2.2
other wise the kit in the first picture is your only option
in my search
hin nation
02-07-2008 12:48 PM
Teddysnca
07-13-2007 10:27 AM
