HELP!!!!! ECU throws a 31 code
The ECU throws a 31 code(On a 95 Camry LE (5SFE))...which i have read its a M.A.P. sensor problem...BUT i just replaced it with 3 different ones and the problem still persist...
What the car is doing?!...Well...it starts fine...BUT soon after the idles starts to go back down to the 1k range...it starts to bog down and trying to cut off...unless i accelerate it but then it acts as if it is clogged by something and eventually even accelerating it it starts to die out until cut completely off...Ive replace the (E.F.I) temp sensor...IACV and M.A.P. sensor...any help PLEASE |
See private message.
I thought i should post the problem i found. Even though its the most simplest and made me feel like a dumbass...just because i should've thought about that first...when i checked if fuel was coming to the rail...now after 4 months digging and replacing worn/damaged vacuum hoses and sensors...come to find out...my lady put mixed (oil/gas) into the thank thinking it was gas...SMH...well after i drained the tank and changed the fuel filter and spark plugs...the camry is up and running like a champ...i wanna thank toyomoho for helping me to find alot of bad sensors using the diagram he provided...now to drive the camry...
Glad to hear a happy ending!
Toyomho is the guru! |
Oh yes...very helpful i must say
