Sponsored by:
Sponsored by:
High Idle when COLD
Old 12-31-2008, 08:38 PM
kingcat's Avatar
Default High Idle when COLD
Have a 1990 2.5 V6, when cold the high idle is about 1700rpm. Is this normal????
Another question is; it shifts hard into reverse or drive when cold...otherwise it shifts OK....normal???
Thanks
Dan
Old 12-31-2008, 09:34 PM
diver1972's Avatar
Default RE: High Idle when COLD
I'm pretty sure that it's normal. I'm not familiar with that model year and what the ECU map calls for, but it's pretty likely that the ECU map calls for that high of an idle when the ambient air temp. is pretty low. What wastheoutside air temp. at the time?
I'm sure that someone else will chime in here with more certainty.
Yes, this is completely normal. It'sdue tothe higher idle and transmission linkages being cold. Everything is just more "sticky" or "rough" when it's cold outside.
Old 12-31-2008, 10:42 PM
MoonRiver's Avatar
My wife's 02 Camry V6 starts up at about the same rpm. My 07 Infinity G35 6MT at 2000 RPM. Her Camry even jolts as it shifts to D then let go, which is caused by the high RPM. Hope this eases your concern.
foxyroxy111298
04-19-2012 10:15 PM
sontakke
09-04-2007 05:27 AM
dmend
07-05-2006 01:24 PM
marc780
04-10-2006 06:22 PM
Quick Reply: High Idle when COLD
