How to jump Fp/B+ terminals?
I've seen a lot of posts discussing jumping FP and B+ terminals to test your fuel pump because it bypasses the relay and MAF sensor. But can someone please explain, in simple, practical terms how to do this on a 2002 Camry SE? First off, where, precisely is the diagnostic connector that has these terminals (under the hood, etc.)? Most of the posts I've seen look like they are from older vehicles with pre OBD-II diagnostic connectors. Can that only be done on older vehicles?
Ok. Thanks so much. So, I jumped the C/OPN relay and the fuel pump kicked in and the car started up and idled (a little rough, but I attribute that to relearning the idle after removing the neg battery cable) until I turned it off after about 5 min. It was low on gas, so I put about four gallons in. Then when I went to start it up with the slightly fuller tank, I jumped the relay again, but nothing. No whirring, no start up, etc. I checked the voltage to the electrical connector housing (blue/black=positive, thanks!) and it read normal, battery voltage. I then connected the car battery directly to the corresponding terminals on the fuel pump assembly via a set of jumper cables through the window and a few wires with little connectors. I got no discernible movement from the pump. I even checked the voltage directly at the two terminals on the pump to confirm that they had battery voltage.
This seemed pretty definitive to me that the pump is the issue and I had just witnessed the last gasp of it, but I wanted to check: Is there anything I could be missing? I got a full ~12.6V at the pump through the circuit and then directly from the battery, which seemed pretty conclusive. But I didn't know if there's some other signal that could be telling the pump not to run. It's just odd that it ran for 1500 miles (since I first started having starting problems and a 0171 code) and never cut out on me once the car had started. Thanks again for all your help.
Hello, friend. A couple of months ago I had a problem with my Camry 2004, I couldn't start the engine. I thought that the problem is in the fuel pump, but I was wrong. Everything was much more simple than I thought. I have just read an article on https://www.otopartshop.com about how to jump start a car, if you have an empty battery, and it worked. The problem was just in that empty battery. I have bought a new one and everything is really fine now!
Bam Bam 65
10-20-2013 05:54 PM
