IAC Valve problem???
99 Camry 4cyl w/ 220k miles. Car started having rough idle problem. Checked plugs, caps, rotors, etc. I've read that IAC valve problem is common. With the car on and valve unplugged, car idles very low. When the valve is plugged in, car idles higher (still rough) but I hear air chocking sound coming right where the IAC valve is. It's very noticeable w/ the intake tube off. Does this sound like I need a new IAC valve?
RE: IAC Valve problem???
What idle rpm are you getting? At 220k miles I'd do a compression test for rough idle. You could also pull one plug wire at a time to see if roughness stays the same or gets worse. That may isolate it to one cylinder.
car also threw a code P0505
Code is for IAC valve. Stuck or closed IAC valve-circuit problem, problem A/C circuit or loose air intake hose.
tried to clean w/ some carb cleaner as suggested by a member but that didn't help. I hear alot of hissing sound coming from it.
ORIGINAL: jones100001 I hear alot of hissing sound coming from it. |
carb cleaner usually spells death for the iac, u most likley have a leak, ad now need a new iac
new spark plug wires solved the problem
