Install Keyless
My Camry has central locking system, but I'm missing the keyless entry.
I purchased a kit and would like to install it (done that once successfully, on a different car). This Camry having its controls on the driver's door, I figure I could place there my keyless entry receiver, conveniently tapping its connections to the existing control unit, once I locate them. A number of wires are going to/coming from that control unit. I will only need 4: +12V(constant), Ground, Lock Pulse and Unlock Pulse. Openning the control unit, I could see on the PC board some terminals which seem waiting for such addition (suggestive markings). I also unplugged the connector and using my multimeter, searched for the +12V(constant), but could not find it. Is it because of the unplugged connector? It would be of great help if I knew the color coding of all those wires. Thanks for your attention. |
See Private Message.
I think it should be indicated on the manual...not sure about the coding because I don't memorize it but its should be in the manual.
