Installing rear seatbelts on 1992 Camry
Hi, Can anyone tell me how to go about installing the rear seatbelts on to my 1992 Camry. I just discovered last week that I do not have them installed on the car and hence ended up buying original camry seatbelts from the scrappy.
Do i need to remove any rear panels - trim i.e, or boot lining, side cushions or the actual rearseat? Thanks Rob |
RE: Installing rear seatbelts on 1992 Camry
If no shoulder harness pull up on the front of the rear seat then pull forward. There is a press in tab under the seat a little way inboard from the side of the car. Pull up on the seat in this area to pull the tab out of its slot in the chassis.
Remove the seat and you will see the bolts holding the belts to the chassis. |
