intake gasket guestion-help
can I reuse the factory metal intake gasket on a 97 camry 2.2L ... I put on a new gasket and then had to loosen intake bolts since a brace was jammed where I couldn't get it into the proper position...so can I just tighten my new gasket from toyota, metal with raised ridges around ports, or must I get a new one
RE: intake gasket guestion-help
you should be able to reuse it
