Just got 2004 Camry with 100K on it. what maintenance is needed?
Just got a used camry with 100k miles on it. wanted to know the following on what needs to be done at 100k and what
Engine oil - ? Oil Filter - ? Transmission oil - ? Transmission Filter - ? 100k mile maintenance - ? Tune up - ? Spanks plugs - ? thanks |
so it's 7 yrs old, only medium mileage. Good.
When I get a used car I do all the fluids*, oil filter, plugs, and inspect the air filter and brakes. Some shops offer a fresh car general inspection for <$50; might be worth it. Unless you can find different from contacting the prior owner - assume, at 100K miles, the timing belt needs to be replaced. When you replace it is your call... * engine oil, radiator fluid, brake fluid, tranny. |
