Leaky trans on 92 camry
I replaced the axels on my 92 camry (4 banger) and now the driver side has a drip it seems.. but when I got under to look, it didn't look like it was coming from the seal on the trans. is there anything else that would be leaking? say like a speed sensor or anything?
RE: Leaky trans on 92 camry
the whole trans is on the drivers side. but the most common seals that leak are trans pan, axle seal also make sure your drain and fill plugs are ok..
Damn.. it was deffinatly comming from above the pan.. it's more then likely the seal which means I have to pull the axle AGAIN..... anything I should know about getting the seal out, any tips/tricks or is it a basic pull and replace?
