Loose manual shifter
I tried using the search option and could not find an answer. I have a 1992 Camry with a manual transmission and when it is in gear the shift lever has a lot of slack. I'm pretty sure it is a bushing but can't find one anywhere does anyone know how to fix this? Tia
1 Attachment(s)
i cant find a 92 manual stick sleeve or bushing kit for sale on line
the camry 92 repair manual i have is no good looks like a diy job get to the shift stick assembly see where the slop is..... take apart.....and improvise cant see a manual kit listed this site http://parts.lakelandtoyota.com/prod...category=21655 |
Best bet for is a dealer as Dirty Hands states.
The shifter uses two push/pull cable. |
I agree with Dirty and Toyomho.
You may also have a friend jiggle the shifter (car off and parking brake on) while you check the linkage where it connects to the tranny. I doubt this is where the slack is but I think it would be easier to change any worn parts here than at the actual shifter, there's lots of little bushing in the unit! |
