Low Beam Headlights Not Working-2000 Camry
https://cimg2.ibsrv.net/gimg/www.cam...3aacfe0c1c.jpg
I have replaced the switch, relay under the hood, the fuses are fine and also replaced a headlight bulb all with no luck. I'm stumped as to what it could be. I've read some had success with replacing the integration relay under the dash or maybe a loose ground. Would anyone happen to know where the integration relay is in the pic I posted? |
Does the car have daytime running lights, auto light off, etc?
(Post 101616)
At night when I start the car the day time lights turn on, but turn off when I turn the switch to low beams. |
Did you check both high and low beams fuses?
Do the high beams and flash work OK? Both high/low beam filaments receive 12v power. The headlight circuitry then routes the ground wiring to turn on/off a filament, engage DRL, etc.. |
High beams work fine and so do the flashers. I've been driving at night with my high beams on for a week now.
I've checked all fuses and they all are fine and also replaced the HEAD relay. I still hear loud clicking coming from the fuse box every time I turn the HL switch on. |
Which relay did you replace? There should be a DIM relay that controls the low beams.
https://cimg9.ibsrv.net/gimg/www.cam...1c9e11dd8b.jpg
Only the HEAD relay as I mentioned above. I didn't know there was more than 1 relay that controlled the lowbeams. So when I went to the junk yard I only grabbed the head. I'm hearing a loud clicking noise when I turn the switch on to the lowbeams. I'm probably going to make another trip to the junk yard this week to grab a integration and DIM relay. I posted a pic of the relay I replaced. |
Relays are Headlight, DRL No 2 and 4 and DIM.
Try to narrow down the area of the click. |
