need some help rear brake light
i have a toyota 1999 camry, when i step onthe brake only one back light comes on, i have heard this is a problem in camrys, i was told to hit the reset button and it will reset itself? how long do i hold the reset button in? and i knowthe car has to be turned on, i checked the bulbs and they are fine. any help woul dbe appreciated
RE: need some help rear brake light
Brake Light Switch 1. Lift the locking tab on the switch connector and disconnect the wiring. 2. Remove the hairpin retainer, slide the stop lamp switch, pushrod and nylon washer off of the pedal.Remove the washer, then the switch by sliding it up or down. (On trucks equipped with speed control, the spacer washer is replaced by the dump valve adapter washer.) 3. To install the switch, position it so that the U-shaped side is nearest the pedal and directly over/under the pin. 4. Slide the switch up or down, trapping the master cylinder pushrod and bushing between the switch side plates. 5. Push the switch and pushrod assembly firmly towards the brake pedal arm. Assemble the outside white plastic washer to the pin and install the hairpin retainer. (Caution: Don’t substitute any other type of retainer. Use only the Ford specified hairpin retainer.) 6. Assemble the connector on the switch. 7. Check stop lamp operation. (Caution; Make sure that the stop lamp switch wiring has sufficient travel during a full pedal stroke!)
________________________________
â–“ Jeep Grand Cherokee Water Pump â–“
rapala13
10-03-2013 04:49 PM
gwar28
11-05-2008 11:26 PM
