2008 Solara passenger door window won't work
Passenger door window stopped working. Neither passenger nor driver door switch will work. However, all-windows switch on dash does operate the window. So, it's not the motor and I can't imagine both door switches would fail at the same time. The problem must be between the switches and the motor and common to both door switches. Any suggestions where I should start looking?
What works and what does not?
Passenger window stopped working and neither the master switch or individual passenger door switch works? Thus no switch works this window?
But all windows switches operate the same window?
Neither the driver's door switch for that window nor the pass. door switch will operate the pass window, but the all-windows switch on dash will operate ALL windows. This simply means the pass. motor is working so the problem is elsewhere. Unless both door switches failed simultaneously, which I doubt, the problem is somewhere that is common to both door switches. If I had a wiring schematic, I could figure it out, but don't want to start tearing things apart without some idea of where to start.
The single dash switch controls all windows at the same time and its circuit is independent of the door switches.
Elijah17
07-02-2009 11:27 PM
