New bottom please help
Hi i am new and need help. I bought this 4 cyl. 98 camry that has no distributer. The car came with spun bearings but I thought I could skate cheap I just put new bearings the camry ate the bearings so fast. So I went and got a 96 2.2 short block same block so I thought, now I am not so sure as I have power to the coil but when I crank the motor I get about .5 volts and that is all i can get out of this new short block, and the same top end from the original 98 distributorless 2.2 (no spark) I have checked the ohms for the crank sensor and do not know how to check the igniter part of the coil the secondary has 13 ohms please help abrat6917
life is good
this reply is for boricua who i am so gratful to, no I did not use the right gear and i have no idea where to get one. I think I will look on ebay I am seriously gratful thank you. I have no idea what thought the crank sensor was reading off of, you are the best
jack
jack
Thank you so much for your help !!!!!!
Thank you boricua The new motor came from a 50% off sale at pick a part as I am at present poor,so when I took the motor back for the core refund i was giving up any chance of easy fix. So I figured what tools I needed and headed off to pick a part I knew it would be a job as they do not normaly have cars toyotas new enough for that gear. Any way I found one and a couple hours later the car started your knowlege and kindness are the bomb I am truely graitful. my wife was starting to think the camry was going to never start. thank you so much
jack
jack
Last edited by abrat6917; 06-02-2012 at 02:13 AM. Reason: I forgot the name in my thank you letter
kqmkqm
05-01-2010 08:44 AM
