chaoticwolf88 |
12-20-2011 08:29 PM |
No Spark...Help
Hello All, I hope i can get some much needed help from anyone willing to do so. Ok i have a 1991 Camry 2.0 5 speed, the other morning went out to go to work and it wouldn't start, it turns over but no start I thought it was a fuel pump prob because it ran fine the night before so to trubleshoot i took of air intake and sprade starter fluid...nothing. So pulled a plug to check for spark and there wasn't any, So for the last two days i have been trying to do all the normale things to get spark but nothing. the ohm res. on the plug wires is in spec. the Ohm res. on coil prim and sec is in spec, volt res at coil is 12 so igniter checks out i did replace all relays/checked fuises etc. thinking mabee distributer was bad i got a new one along with new coil and still no spark i have no idea mabee im overlooking something???? help help:confused::confused::mad:
