overdrive light on dash
hello i have used my mums sv21 to jumpstart my car and now the "O/D OFF" light on her dashdoesn't appearwhether i switch overdrive on or off. what's the go here? |
RE: overdrive light on dash
a fuse may have blown.
does it still operate? if so then its proabbly just the bulb. |
asnodrogkam said check ur fuse's or if there is a relay for the over drive under the hood in the relay's box ... some gear box comes with an electrical switch connected to thegear ... check it out .. am not so sure coz am still exeploring my camry as i used to mostly drive american cars.
all the best :) |
There will not be one fuse for just that light. So unless other lights don't work, it's not a fuse. I'm assuming it's the light that goes on when you hit the switch on the shifter to kick the O/D off? Does the O/D actually go off even without the light? I'd go with light bulb then look at switch.
I didn't realize my 98 Camry 4cyl has O/D. So when I started the car after work I noticed that the "O/D Off" light was on. It wasn't on before. Since it wasn't on before, I'm assuming I may have switched it off sometime today. But I don't remember do so. Not to mention that I have no idea where the O/D switch is on my car. Can anyone point me in the right direction.
If I didn't hit the switch, what could be the reason why it is now off? Thanks |
look around the shifter knob, u'll find it. ;)
Sweet. Thanks for the tip. The whole time I've had my car, I never noticed that switch.
