bigstew25 |
08-13-2009 05:52 PM |
Passenger Side Trans Output Shaft Seal Leaking
He we go everyone follow close. I have a 2002 Camry LE with a four cylinder auto. A while back I had a noise that I thought was a wheel bearing. I talked myself out of that and decided it was the carrier bearing on the right side axle shaft. After replacing the axle shaft with a remanufactured axle shaft from O'reillys (it had a new bearing on it) I still had the noise. Guess what, it was the wheel bearing like I thought. I should have known better to go with my first thought. Anyway here is my problem. After replacing the axle, my output shaft seal on the tranny was leaking. I got a new seal (same part number) from Toyota and put it in. The new one leaks as well. Did I get a bad or undersized axle from O'reillys or just what is going on. I sure as heck don't want to spend $600 on a new toyota axle for a car that has 160000 miles on it. Any help would be great. Thanks.
