power door lock problem
1996 Wagon
Key will lock and unlock all locks. Passenger inside switch will lock and unlock all locks. Drivers inside switch will only lock all locks. I cannot unlock all locks with the drivers inside door switch. Master switch was cheap enough, so I just replaced it. It's a wiring problem. Anyone have a wire diagram for it???? Any ideas???? |
Does the master switch unlock the drivers door?
Typically this is a broken wire issue between drivers door and chassis caused by the harness flexing when the door is used. |
