Sponsored by:
Sponsored by:
Power Mirror Switch Wiring Help Needed
Old 11-30-2012, 08:15 PM
trtrtr59's Avatar
Default Power Mirror Switch Wiring Help Needed
Hello. I am new to this forum. I don't have a Camry, but do have a 2002 Camry Power Mirror Switch that I need a wiring diagram or help with. My project is upgrading to power mirrors in a '99 Tacoma.
I attached a picture of the Camry switch back. It is a 10 port connector, but only seven of the pins are present and active, i.e., no fancy heated mirrors just simple up/down/left/right adjustment. From right to left the switch ports are numbered 1 through 10. #1 is empty, #2 light green w/red stripe, #3 Drk Grn w/red stripe, #4 Blue w/black stripe, #5 black w/red stripe, #6 yellow w/grn stripe, #7 white w/black stripe, #8 solid gray, #'s 9 & 10 empty.
Am hoping one of you have the wiring diagram. That would be easiest.
I know white w/black stripe is ground, I would guess the solid gray is power, but I am a lost on the rest. The wires are running to three wires each power mirrors. I have a multi-meter, but I'm pretty simple on electrical stuff. I can check for continuity and power but am iffy on ohms and such, but can muddle through if I have good directions.
Take a look, let me know what you think. I appreciate any help. Thanks all!
Attached Thumbnails Power Mirror Switch Wiring Help Needed-02-camry-switch.jpg
Old 11-30-2012, 09:55 PM
LH Mirror
Black/Red = Motor L/R
Blue/Black = Motor Up/Down
Yellow/Green = Common ground for all motors.
RH Motor
Light Green/Red = Motor L/R
Green/Red = Motor U/D
White/Black = Ground for switch
Gray = Power
Old 12-01-2012, 11:21 AM
trtrtr59's Avatar
Ah sensei, you nailed it! Thank you so much for the very able assist. You made short work out of a handful of wires!
Old 12-01-2012, 07:14 PM
Great!
Old 07-16-2013, 03:14 PM
Linzeereed's Avatar
Default Camry rear view mirror wiri g
I have a 99 Camry that I'm trying to replace the passenger side rear view mirror on. The Camry is Japan made and I ordered a replacement mirror that is US made. I'm having trouble matching up the wiring. The car's wires are red, black and white and the mirror's wires are green, black and yellow. Anybody have a suggestion as to how to match them up? Any help would be appreciated. Thanks!
dabruce15
01-03-2012 12:17 AM
cykaaro
12-26-2007 05:11 PM
trueblue94le
10-16-2007 11:40 AM
av98
11-18-2006 03:21 AM
famleof5
09-19-2006 10:20 PM
Quick Reply: Power Mirror Switch Wiring Help Needed
