Power Steering Issue: Pulsation
2000 camry 4 cylinder.
Pwr fluid level appears fine...I did add a little (1 oz as best) to reservoir. Noticing a pulsation in steering wheel with turns at low speeds....... Thoughts/fixes? |
check hub bearings. and CV joints boots. even uneven worn tires may cause this. cross rotate tires, see what happens.
oh, not to forget - tie rod ends.
bearings would be, check those out might have few problems there.
roger roger....will check those out!
