Power window problems
I recently posted about a power window issue. Received great helpful suggestions which I did. I replaced all the broken and non broken wires that go through the door hinge. Now the issue I have is that the p/s front and the d/s rear. When you first start the car the windows will go down but don't go back up or go a little then stop and if you try to operate the windows again they do nothing. The d/s front and the p/s rear seems to work fine. (Prior to original problem the broken wires the d/s front was the only window that worked properly) Need Advice. Thanks:confused:
Do the individual window switches work OK?
(Post 88715)
I checked the individual switch operation on those two windows and I get the same issue as I get at the main control.
Hi hunter the information may help for you.....
The power windows on your Toyota Camry CE are raised and lowered by the automatic window regulator contained within the door. If the regulator fails, you will not be able to raise or lower your Camry's windows. If this occurs, you should check the fuse, the regulator's electrical wiring connector or the regulator itself. Those are the three most common issues with malfunctioning power windows |
Are you stating the problem windows work differently when the car is first stated?
Might access the individual window switch wiring to each problem motor. Then apply 12v +/- to directly to the motor (red and green wires). If the window now works OK, the issue is most likely with the wiring. The window wiring is such that if one window works OK at the door and individual switch, the window electrical system in the drivers door is getting power. The issue still could be individual door window wiring or as stated a problem with the motor or regulator. |
